Here are the videos of the speed improvement from 16 to 25Mhz SPI speed:
@ 16Mhz
@25Mhz
It's not very noticeable as the speeds start to match the phone's camera fps. So we'll look at the counters instead.
The counters on the display show the value of the timer 1 running at 80Mhz.It counts to ~102M on 16Mhz and to ~72M on the 25Mhz for a set o 10 frames (16 bit mode). There's a bug somewhere because I clear the timer value from one iteration to the other but it keeps the value. So I added an extra line with the difference on the bottom.
This results in a time reduction from 126ms to 90ms for a single full frame write. Equivalent to about 11fps. Not super smooth but I won't be running video on this :)
More than enough considering the SPI interface and the "big" screen resolution.
I could improve even more by using the SPI FIFO but doesn't seem to get a lot more than this and would require a lot of SW changes.
