ok the idea with sliding regulated extension is put a way for now and just at simple extension is made. this is also making the rotating in the XY direction out on the monitor vesa mount instead of back on the rail. this makes it possible to slide on the rail to adjust the distance from the rail to the mointor. estimated printing time 3-4 hours.
