Just keep planning
A project log for Making a homemade 6802 computer for fun.
I am going to use an AMI S6802P (Motorola 6802 Clone) and make a computer around it.
jeffrey-paullJeffrey Paull 06/03/2015 at 18:540 Comments
I need more stuff if I am going to use the MOS 6560 chip for video. The 6502 isn't far off from the 6800 series chips if what I am remembering is correct. I believe there was a whole court case from Motorola to MOS because they were selling the 6502 CPU that is compatible with 6800 series for $25 instead of Motorola's $100+ and Intel's $100+ CPU.
The 6502 is on the top left and the 6560 is on the middle right.
I am assuming I need the 3 Octal Bus Transmitter/Receivers at this time.
