Hummingbird
This is an internet of things device which will give predictive information about the environment.
This project uses a zigbee mesh and GPRS SIM900 card to communicate to a server. The server conducts an analysis on the data and provides the user with real time information as well as forecasting.
Overview
Hummingbird is a hardware scheme designed to interface with a free VivaPlanet (http://www.vivaplanet.io/) data-analysis engine. Hummingbird will send information about the health of it's environment to the VivaPlanet data-analysis engine to allow the user to predict and better understand the health of the environment of Hummingbird. Anyone can use an ethernet, GPRS or WiFi enabled Internet of Things or wearable device to interface with the VivaPlanet data analysis engine. These are the instructions on how to build a simple serial interface to this engine.
There are three major parts to this project. There is the free VivaPlanet data-analysis engine, the coordinator node and the sensor node. The senor node(s) send information to the coordinator node. The coordinator node manages inputs from various sensor nodes and sends this data periodically to VivaPlanet. The user can then go look at the big data analytics on their free VivaPlanet website.
We chose GHI (https://www.ghielectronics.com/) and Seeed (https://www.http://seeedstudio.com) to purchase a lot of the hardware. GHI uses .NETMF capable hardware which is great. I'm using .NetMF 4.2 for this project.This means I can write embedded code in C# and have it compile and run on the GHI hardware. This is really great because I get all of the power and flexibility of C# when coding. There is some overhead in this on the hardware side but for a light weight application like this it is a really great way to quickly prototype.
  • 1
    Step 1
    Step 1: Building the sensor node
    A functional test can be easily constructed with 2 XBees and a BJT Oscillator (more details on how to do this are here: http://meca-labs.blogspot.com/2014/05/fun-with-xbe...) The sensor node is the easiest node to assemble it is shown in Figure 2 below. We hacked into a solar powered light and added a moisture sensor to the bottom. Then we ran a wire up to the top and stored the XBee (series 2) and power system. The XBee has 4 ADC converters and we used one of these to poll the moisture sensor and send the information to the coordinator node. We just used XTCU to program the sensor node.
    Figure 2: Functional example of 2 XBees sending ADC data from a BJT Oscillator to a coordinator node.
    Figure 3: Sensor node deconstructed
    Figure 4: Sensor node in action
  • 2
    Step 2
    Step 2: The coordinator node
    The coordinator node is also the same solar power set but it consists of a GHI CerbuinoBee an XBee (series 2) and some sort of way to connect to the internet. We've demonstrated this project with a GHI GPRS module, shown in figure 5, and a USB-Serial Module. Using the Serial interface in C# is really simple and that's what we'll focus on here. Getting the GPRS working is tricky and is another project in itself.
    Figure 5: Coordinator node with a SIM900 GPRS Module.
  • 3
    Step 3
    Step 3: Connect to VivaPlanet
    This next step is a bit more complex and requires some C# and visual studio with the Gagetter software from GHI Installed. This will take some time...persist it will be worth it in the end...There are a lot of great tutorials out there on how to get this installed on your machine so I won't go into that here. I spent some time getting all the right references so I've taken a screen shot of all the references I'm using in this script.
    Figure 6: References to be used in Visual Studio
    Here is the full script. There is a lot going on here but for the most part it is obvious. I'm taking a XBee packet and writing it's ADC values to a file. Then I'm reading this packet from the file to the serial output. I'm doing this every 5 seconds. There are several of debug points in this script and I've left them in. You can literally use this code and get some real time data analytics from your sensor system. You can even send pictures. But this is more complex and may be in a different project all together.
    using System;
    using System.Collections;
    using System.Threading;
    using System.Text;
    using System.Security.Cryptography ;
    using http://System.IO; //for series 2
    using http://System.IO.Ports;
    using Toolbox.NETMF;
    using Microsoft.SPOT;
    using Microsoft.SPOT.Hardware;
    using Microsoft.SPOT.Presentation;
    using Microsoft.SPOT.Presentation.Controls;
    using Microsoft.SPOT.Presentation.Media;
    using Microsoft.SPOT.Presentation.Shapes;
    using Microsoft.SPOT.Touch;
    using GHIElectronics.Gadgeteer;
    using Gadgeteer.Networking;
    using GT = Gadgeteer;
    using GTM = Gadgeteer.Modules;
    using Gadgeteer.Modules.OpenSource;
    using Gadgeteer.Modules.GHIElectronics;
    //using Gadgeteer.Modules.DLSys;
    //using Gadgeteer.Modules.Mekalogic;
    using GHI.OSHW.Hardware;
    using NETMF.OpenSource.XBee.Api;
    using NETMF.OpenSource.XBee.Api.Common;
    using NETMF.OpenSource.XBee.Api.Zigbee;
    using NETMF.OpenSource.XBee.Util;
    using http://Microsoft.SPOT.IO;
    //This program will write data to the SD Card for the webClient to access
    namespace VivaPlanetEmbedded
    public class IOSampleDecodedEventArgs : EventArgs
    public string DecodedPacket { get; set; }
    public IOSampleDecodedEventArgs(string myString)
    this.DecodedPacket = myString;
    public class IoSampleListener : IPacketListener
    public bool Finished { get { return false; } }
    public XBeeResponse[] Packets;
    UsbSerial usbSerial = new UsbSerial(1);
    static bool flash = true;
    public event EventHandler IOSampleDecoded;
    public void ReportPacket(string packet)
    EventHandler handler = IOSampleDecoded;
    if (handler != null)
    handler(this, new IOSampleDecodedEventArgs(packet));
    public void ProcessPacket(XBeeResponse packet)
    if (packet is IoSampleResponse)
    IoSampleResponse myPackets = ProcessIoSample(packet as IoSampleResponse);
    public IoSampleResponse ProcessIoSample(IoSampleResponse packet)
    DateTime time = new DateTime(2007, 06, 21, 00, 00, 00);
    Utility.SetLocalTime(time);
    try
    for (int ii = 0; ii < 5; ii++)
    { //working this logic here because this is the closest point to the raw data. Ideally this would be fastest?
    //String format: Address HasData DataId SensorType Time Value
    string s = "^" + packet.SourceAddress.Address.ToString() + "^" + "true" + "^" + "0" + "^" + ii.ToString() + "^" + time.TimeOfDay.ToString() + "^" + packet.Analog[ii].ToString() + "\r\n";
    ReportPacket(s);
    catch (Exception e) //Catch any exceptions
    Debug.Print(e.ToString()); //print the error to the debug ouput
    return packet;
    private void DebugPrint(string str)
    flash = !flash;
    Debug.Print(str + " \r\n");
    try
    usbSerial.SerialLine.Write(str + " \r\n");
    catch (Exception e)
    Debug.Print("USB Not enabled" + " \r\n");
    Debug.Print(e.ToString() + " \r\n");
    public XBeeResponse[] GetPackets(int timeout)
    throw new NotImplementedException();
    public partial class Program
    public const string DeviceSerialNumer = "17564321";
    private string _root; //volume
    bool flash = true;
    bool newPackets = false;
    //set up the Xbee
    const string serialPortName = "COM1";
    const Cpu.Pin resetPin = GHI.Hardware.FEZCerb.Pin.PB0;
    const Cpu.Pin sleepPin = GHI.Hardware.FEZCerb.Pin.PC13;
    XBee xBee = new XBee(serialPortName, resetPin, sleepPin) { DebugPrintEnabled = true };
    // This method is run when the mainboard is powered up or reset.
    void ProgramStarted()
    Debug.Print("Viva Planet!");
    try //both usbSerial.Configure and usbSerial.Open()have different exceptions but it is rare that they will triggered in this specific code
    //mount the SD card
    GHI.OSHW.Hardware.StorageDev.MountSD();
    //configure the usbSerial port
    usbSerial.Configure(9600, GT.Interfaces.Serial.SerialParity.None, GT.Interfaces.Serial.SerialStopBits.One, 8);
    //if the port is not open then open it
    if (!usbSerial.SerialLine.IsOpen)
    usbSerial.SerialLine.Open();
    DebugPrint("opened the serial port");
    if (VolumeInfo.GetVolumes()[0].IsFormatted)//check to make sure the SD card is formatted
    _root = VolumeInfo.GetVolumes()[0].RootDirectory;
    DebugPrint("SD Card is formatted: " + _root);
    else
    DebugPrint("SD Card is not formatted"); //print the error to the debug ouput
    DebugPrint(e.ToString()); //print the error to the debug ouput
    //Gets the command data from the intertubes. This is interrupt driven.
    usbSerial.SerialLine.DataReceived += new GT.Interfaces.Serial.DataReceivedEventHandler(SerialLine_DataReceived);
    //Implement the interface member
    IoSampleListener sample = new IoSampleListener();//created 1x only
    sample.IOSampleDecoded += sample_IOSampleDecoded;//every time the event is raised (report packet)
    //add the listener
    xBee.Api.AddPacketListener(sample);
    // initialize the loop timer and send a file to the server
    GT.Timer timer = new GT.Timer(5000);
    //set the interrupt
    timer.Tick += new GT.Timer.TickEventHandler(timer_Tick);
    timer.Start();
    //this method is an event handler that decodes the packet within this class
    private void sample_IOSampleDecoded(object sender, EventArgs e)
    IOSampleDecodedEventArgs eventargs = (IOSampleDecodedEventArgs)e;
    string packet = eventargs.DecodedPacket;
    writeToFile(packet); //write the packet to file
    newPackets = true;
    private void writeToFile(string packet)
    //initialize variables
    string fileName = Path.Combine(_root, "file.txt");
    Stream stream;
    try
    //write it to file
    if (File.Exists(fileName))
    stream = File.OpenWrite(fileName);
    stream.Position = stream.Length;
    else
    stream = File.Create(fileName);
    using (var writer = new StreamWriter(stream))
    writer.WriteLine(packet);
    DebugPrint("wrote: " + packet);
    stream.Dispose();
    catch (Exception e)
    private void timer_Tick(GT.Timer timer)
    // Make sure the file exists
    // Load the file into a string
    DebugPrint("tick");
    if (newPackets)
    //populate the device struct with the measurements
    DeviceReport device = readPacketData();
    //Send the data
    NotifyServiceQueue(device, null);
    newPackets = false;
    else
    DebugPrint("no new packets");
    private DeviceReport readPacketData()
    Stream stream = null;
    DeviceReport device = new DeviceReport(); //this needs to be global
    try
    //read it to file
    stream = File.OpenRead(fileName);
    using (var reader = new StreamReader(stream))
    string packet;
    while ((packet = reader.ReadLine()) != null)
    device = parseVivaPacket(packet);
    DebugPrint("read: " + device.Address);
    stream.Dispose();
    else
    DebugPrint("The filename does not exist");
    catch (Exception e)
    return device;
    private DeviceReport parseVivaPacket(string packet)
    Sensors deviceSensors = new Sensors();
    char[] charSeparator = new char[] {'^'};
    string[] result;
    result = packet.Split(charSeparator, 1);
    device.Address = result[0]; //the actual address
    device.HasData = (result[1] == "true"); //if true then true else false
    device.DataId = result[2]; //not sure how to use this one...default it to 0
    switch (result[3]) //sort the sensor type
    case "0": //TEMP
    deviceSensors.Time = result[5];
    deviceSensors.Value = result[6];
    deviceSensors.SensorType = "TEMP";
    device.DeviceSensors[0] = deviceSensors;
    break;
    case "1": //LIGHT
    deviceSensors.SensorType = "LIGHT";
    device.DeviceSensors[1] = deviceSensors;
    break;
    case "2": //PH
    deviceSensors.SensorType = "PH";
    device.DeviceSensors[2] = deviceSensors;
    break;
    case "3": //HUMI
    deviceSensors.SensorType = "HUMI";
    device.DeviceSensors[3] = deviceSensors;
    break;
    default: //other unknown sensor
    deviceSensors.SensorType = "other";
    device.DeviceSensors[4] = deviceSensors;
    break;
    return device;
    //This is here for debug usage
    void SerialLine_DataReceived(GT.Interfaces.Serial sender, http://System.IO.Ports.SerialData data)
    Thread.Sleep(500); //let all the data get there.
    int NumberOfBytesToRead = usbSerial.SerialLine.BytesToRead;
    byte[] readInputBuffer = new byte[NumberOfBytesToRead];
    //get sensor data
    usbSerial.SerialLine.Read(readInputBuffer, 0, NumberOfBytesToRead);
    // From byte array to string
    char[] c = Encoding.UTF8.GetChars(readInputBuffer, 0, NumberOfBytesToRead);
    string s = new string(c);
    DebugPrint("wrote: " + s);
    flash = !flash;
    Mainboard.SetDebugLED(flash);
    try
    catch (Exception e)
    void NotifyServiceQueue (DeviceReport device, DataUploadResponse Dataresponse = null)
    DebugPrint("Sending notification to service bus queue");
    DebugPrint(device.Address);
    DebugPrint(device.HasData.ToString());
    DebugPrint(createToken("https://vivaplanetbusservicedev.servicebus.windows...", "DevicePolicy", "zxuC2mrAN0o9lRlZmex/KhwSiF6uSr/Fxe/0lAS52G4="));
    /* need an ethernet connection for this
    http://System.Net.WebRequest sbRequest = http://System.Net.WebRequest.Create (@"https://vivaplanetbusservicedev.servicebus.windows.net/hummingbirdqueue/messages");
    var headers = sbRequest.Headers;
    sbRequest.Method = "POST";
    using (var sbMessageStream = sbRequest.GetRequestStream ())
    //string body = JsonConvert.SerializeObject (device);
    //var bytes = Encoding.UTF8.GetBytes (body);
    //sbMessageStream.Write (bytes, 0, bytes.Length);
    // headers.Add ("Authorization", createToken ("https://vivaplanetbusservicedev.servicebus.windows.net/hummingbirdqueue/messages", "DevicePolicy", "zxuC2mrAN0o9lRlZmex/KhwSiF6uSr/Fxe/0lAS52G4="));
    try {
    DebugPrint("Sending notification for " + DeviceSerialNumer);
    using (var response = sbRequest.GetResponse ())
    DebugPrint("Sucessfully Sent");
    } catch (Exception e)
    DebugPrint("Couldn't post to service bus -" + e);
    private string createToken (string resourceUri, string keyName, string key)
    TimeSpan sinceEpoch = DateTime.UtcNow - new DateTime (1970, 1, 1);
    var expiry = sinceEpoch.Seconds.ToString(); //EXPIRES in 1h
    string stringToSign = Tools.RawUrlEncode(resourceUri) + "\n" + expiry;
    System.Security.Cryptography.X509Certificates.X509Certificate hmac = new System.Security.Cryptography.X509Certificates.X509Certificate(Encoding.UTF8.GetBytes(key));
    var signature = hmac.GetHashCode();
    var sasToken = System.Globalization.CultureInfo.CurrentUICulture +
    "SharedAccessSignature sr={0}&sig={1}&se={2}&skn={3}" +
    Tools.RawUrlEncode(resourceUri) + Tools.RawUrlEncode(signature.ToString());
    return sasToken;
    public class DataUploadResponse
    public string sasUrl { get; set; }
    public string DataId { get; set; }
    public string expiry { get; set; }
    public class DeviceReport
    public string Address { get; set; }
    public string DataUrl { get; set; }
    public bool HasData { get; set; }
    public Sensors[] DeviceSensors { get; set; } //temp, light ext...
    public class Sensors
    public string SensorType { get; set; }
    public string Time { get; set; }
    public string Value { get; set; }
    Next we connect with the serial port and pull the packets from file.txt to the computer. This script opens up a serial connection to the cerbuinoBee and reads in all the sensor data that was written and parses it. It then sends this data to the VivaPlanet server. This is much easier to set up than the .netMF side there are better and worse ways to implement this handshake and I encourage you to find a better way than this.
    using System;
    using System.Text;
    using http://System.Net;
    using System.Web;
    using Newtonsoft.Json;
    using System.Security.Cryptography;
    using System.Globalization;
    using System.Diagnostics;
    namespace HummingBirdClient
    class MainClass
    //added for serial communication
    static SerialPort p = new SerialPort("COM3", 9600, Parity.None, 8, StopBits.One);
    static string sbuffer = string.Empty;
    static byte i = 0;
    public static void Main (string[] args)
    bool res = getSerialData();
    static int planetCount = 0;
    static bool getSerialData() //fire off the event
    string[] names = SerialPort.GetPortNames();
    Console.WriteLine("Serial ports:");
    foreach (string name in names)
    Console.WriteLine(name);
    Console.WriteLine("Using COM3");
    planetCount++;
    if (p.IsOpen)
    p.Open();
    string data_ = "Viva Planet!" + planetCount.ToString() + "\r";
    Console.WriteLine("Writing data: {0}", data_);
    p.Write(data_);
    p.DataReceived += new SerialDataReceivedEventHandler(p_DataReceived);
    ConsoleKeyInfo cki;
    Console.WriteLine("Getting ready to send the data");
    DeviceReport device = parseVivaPacket(p.ReadLine());
    Console.WriteLine("I am done sending the data");
    Console.WriteLine("type any key to send another data transfer");
    Console.WriteLine("Press the Escape (Esc) key to quit: \n");
    cki = Console.ReadKey();
    if (cki.Key != ConsoleKey.Escape)//yes
    Console.WriteLine("Sending more data");
    getSerialData();
    else
    p.Close();
    else
    p.Write(data_);
    ConsoleKeyInfo cki;
    getSerialData();
    else
    p.Close();
    return true;
    public static DeviceReport parseVivaPacket(string packet)
    char[] charSeparator = new char[] { '^' };
    string[] result;
    case "0": //TEMP
    break;
    case "1": //LIGHT
    break;
    case "2": //PH
    break;
    case "3": //HUMI
    break;
    break;
    return device;
    private static void p_DataReceived(object sender, SerialDataReceivedEventArgs e)
    Thread.Sleep(500);
    sbuffer += (sender as SerialPort).ReadExisting();
    Console.WriteLine(sbuffer);
    WriteOutputToTextFile(sbuffer);
    static void WriteOutputToTextFile(string _data)
    string FolderName = Environment.GetFolderPath(Environment.SpecialFolder.Desktop);//set destination as your desktop
    using (StreamWriter SW = new StreamWriter(FolderName + "\\test.txt", true)) //true makes it append to the file instead of overwrite
    SW.WriteLine(_data);
    SW.Close();
    static void NotifyServiceQueue(DeviceReport device, DataUploadResponse Dataresponse = null)
    // need an ethernet connection for this
    http://System.Net.WebRequest sbRequest = http://System.Net.WebRequest.Create (@"https://vivaplanetbusservicedev.servicebus.windows...");
    try {
    Console.WriteLine("Sending notification for " + DeviceSerialNumer);
    Console.WriteLine("Sucessfully Sent");
    Console.WriteLine("Couldn't post to service bus -" + e);
    private string createToken(string resourceUri, string keyName, string key)
    TimeSpan sinceEpoch = DateTime.UtcNow - new DateTime(1970, 1, 1);
    string stringToSign = HttpUtility.UrlEncode(resourceUri) + "\n" + expiry;
    HttpUtility.UrlEncode(resourceUri) + HttpUtility.UrlEncode(signature.ToString());
    return sasToken;
View all 3 instructions
