Over the last two days, we created a list of all of the projects tagged with the correct tags for the 2015 Hackaday Prize or Best Product*. You can find our spreadsheet here:
( Editor: This is now archived. 2015 Hackaday Prize and Best Product Spreadsheet.)
*(Note we're estimating if projects qualify based on the tags and our scraping - our columns on Best Product and the Quarterfinals are not canonical. Please let us know if you see an entry mislabeled.)
PK
forget tooltip....use search!
Nice! Possible to add project titles? Maybe shorten them so it doesn't push other info off screen?
You should be able to see project titles as a tooltip while hovering over the links. Adding the titles was a grey area (and they do vary in size), so that seemed like a reasonable compromise.
Just noticed that--the tooltip is a great call. Works like a charm!
