Today I took the time to program the ATTINY2313A that is the "brain" of my temperature sender circuit board. I used my Bus Pirate as a programmer together with avrdude and it programmed without any trouble. Getting the software to do what I want took another couple of minutes before I discovered that I soldered one LED backwards. After that the board now turns the LED on when pressing a button and off when releasing :)
