so after having to learn a lot about how to use VI and how to edit and save files using VI i was able to fallow this guide up to the part about installing xbmc
http://npapak.blogspot.com/2013/04/how-to-install-raspbian-and-autostart.html
I am at the step of
The user which you're going to run XBMC as needs to be a member of the following groups:
will be compelling the other steps tomorrow
I have had never used VI before sense i am a still very new to linux if you want to learn more about VI here are the guides i used
http://www.lagmonster.org/docs/vi.html
https://www.washington.edu/computing/unix/vi.html
Hatterofthewaste
