Trinket Sensing
About 7 cm * 4 cm * 4 cm
Display:
Temperature, humidity, soil moisture level, barometric pressure, light intensity and altitude (Trinket Sensing will know if it's in the garden or in the flat / 2 different altitudes).
Bus departures and Wifi configuration menu
Control:
Door locked status
Boiler
More:
Sensors values will be saved on a local web server in wifi.
Works on battery (with trinket USB charger)
Project Status:
Door locked controler
To Do (AtTiny + door closed sensor + ESP8266)
Boiler controler
To Do ( AtTiny + Servo + ESP8266)
andriy.malyshenko
