Buy
https://www.adafruit.com/products/1393
Learn
https://learn.adafruit.com/adafruit-sharp-memory-display-breakout
(Link looks down today - http://www.downforeveryoneorjustme.com/learn.adafruit.com/adafruit-sharp-memory-display-breakout)
C++ Library
You need the Sharp and GFX libraries from Adafruit
https://github.com/adafruit/Adafruit_SHARP_Memory_Display
https://github.com/adafruit/Adafruit-GFX-Library
Hardware
Vin | 3.3 V |
Gnd | Gnd |
CLK | Trinket Pin 9 |
DI | Trinket Pin 10 |
CS | Trinket Pin 4 |
Arduino code
#include <SPI.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SharpMem.h>
#define BLACK 0
#define WHITE 1
// any pins can be used
#define SHARP_CLK 9
#define SHARP_DI 10
#define SHARP_CS 4
Adafruit_SharpMem display(SHARP_CLK, SHARP_DI, SHARP_CS);
void setup(void) {
void loop(void) {
display.clearDisplay();
display.setTextSize(1);
display.setTextColor(BLACK);
display.setCursor(0,0);
display.setTextColor(WHITE, BLACK);
display.print("It works !");
