In principle when the door bell is pressed, the apartment own door bell light will be activated.
Then the transmitter will detect it through the photocell sensor and transmit a basic data to the receiver.
If the transmitter will receive the data correctly it will turn the relay on and the light and/or the buzzer will turn on.
infreq
bobricius
sophi--e
Christoph Tack
