Mic is on pin 16 and LEDs are on PWM 23 and 22. The Teensy LED lights up for general frequency detection and the two LEDs light up and fade out at two higher frequencies.
#include <Audio.h>
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
AudioInputAnalog adc1;
AudioAnalyzeFFT1024 myFFT;
AudioConnection patchCord1(adc1, 0, myFFT, 0);
int aledg = 23;
int aledr = 22;
int dled = 13;
int brightness1 = 0;
int brightness2 = 0;
void setup() {
pinMode(aledg, OUTPUT);
pinMode(aledr, OUTPUT);
pinMode(dled, OUTPUT);
AudioMemory(12);
// Configure the window algorithm to use
myFFT.windowFunction(AudioWindowHanning1024);
void loop() {
float n;
int i;
if (myFFT.available()) {
// each time new FFT data is available
for (i=4; i<175; i++) {
n = myFFT.read(i);
if (n >= 0.10) {
digitalWrite(dled, HIGH);
if ( myFFT.read(16) >= 0.10 ) {
brightness1 = 255;
if ( myFFT.read(13) >= 0.10 ) {
brightness2 = 255;
analogWrite(aledg, brightness1);
analogWrite(aledr, brightness2);
brightness1 = brightness1 -5;
brightness2 = brightness2 -5;
digitalWrite(dled, LOW);
Richard Hogben
