With just a week to go, and two big boxes full of parts from Mouser on my bench, this week is assembly time.
On the last update, I showed off my new laser-made PCB boards, and now I have the parts to populate it. It's my first SMD design and I have to hand-solder everything as I don't have a reflow oven. So, just is case I mess up with such little time left, I have also ordered through-hole parts to make a perfboard functional prototype. The perfboard version will also be much easier to iterate on, as I use an Arduino Uno in place of a ATTINY841, which means I have enough programming space to include debugging and logging code over serial. I'm left with so little space on the 841 that I can't afford that luxury.
In parallel, I have Bst Polymerase for the wetlab experiments, to generate fluorescent sample to test my spectrofluorometer for the activated Calcien dye.
Wish me luck!
Did you manage to finish it?
Good luck :)
