This project is "Completed" in the sense that it is documented so you can build it. Use the software, it will work. It is "Ongoing" because I have more plans... as follows...
- Adding a web server so you can:
- Make changes to the configuration easily thru a web gui
- Upload different background images and flip them as you like
- Adding plug-in support, to add your own "things" that can be added to the pages without bothering the main code.
- Stock ticker?
- Calendar reminders?
I'll consider all GitHub pull requests.
