Yes, Jessie has been around for a while. I finally updated things to work with Jessie. Interestingly, it was only instruction changes that I found were needed.
https://github.com/n0bel/PiClock/blob/master/Documentation/Install.md
A project log for PiClock - A Raspberry Pi Clock & Weather Display
This project is a fancy Clock and weather display built around a monitor and a Raspberry Pi.
