So we started with implementing a basic voltmeter on the device.
Get ADC -- > Convert to Voltage --> Display on Screen
After being satisfied that it works we started on to adding circuitry for making voltage measurements of a bigger range (0 to 55V)
The device shows the 2 voltage readings in big fonts and the resolution (number of digits after decimal) changes to 1 digit when the voltage is higher than the 9.99 volts.
Also the Square Wave Generator also works, the device can output a square wave of any frequency upto 1MHz and with varying duty cycle.
All code is up on github and committed..!
Moving to the component tester implementation.
This is all very new to me but looks extremely interesting so in with both feet when I can find the time Yea!
