Voltmeter + Sq. Wave Generator
A project log for Engineers Multi Tool
a tool for electronics engineers/students to use - planned to include basic Voltmeter, Ammeter, Component Tester, Serial Terminal etc
zaidpirwaniZaidPirwani • 06/15/2015 at 10:24•1 Comment
So we started with implementing a basic voltmeter on the device.
Get ADC -- > Convert to Voltage --> Display on Screen
After being satisfied that it works we started on to adding circuitry for making voltage measurements of a bigger range (0 to 55V)
The device shows the 2 voltage readings in big fonts and the resolution (number of digits after decimal) changes to 1 digit when the voltage is higher than the 9.99 volts.
Also the Square Wave Generator also works, the device can output a square wave of any frequency upto 1MHz and with varying duty cycle.
All code is up on github and committed..!
Moving to the component tester implementation.
Robert Cohen wrote 06/16/2024 at 05:49 • point
This is all very new to me but looks extremely interesting so in with both feet when I can find the time Yea!
