Hackaday.io Hackaday.io
Sign up Log in
Universal RGB 8X8X8 LED Cube base and driver board
Created a board to allow the best RGB LED projects to all run on the same cube
supertechsupertech
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
30 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 1
    • View all
  • Discussion 0
  • The 2015 Hackaday Prize
View Gallery
170
0
30
6
Team (1)
  • supertechsupertech
Join this project's team
  • The LED Cube DOT COM
  • Instructables
hardware
ongoing project
ChipKit led pic atmega328p cube atmega2560 rgb mega microchip uno arduino 2015HackadayPrize 2015 Hackaday prize 8x8x8 supertech-it nick schulze doug domke kevin darrah uno32 PIC32MX320F128H PIC32MX320F64H
Related lists
Atmel Arduino Projects
Arduino is an open source hardware platform for making interactive objects that can sense and control the physical world.
Atmel® Wireless Projects
Atmel® offers a family of low power Systems-On-Chip (SoC) bringing Wi-Fi connectivity to any embedded design.
Atmel® AVR® Projects
Atmel® AVR® 8- and 32-bit MCUs deliver a unique combination of performance, power efficiency and design flexibility.
2015 Hackaday Prize: Quarterfinalists
Projects that were officially submitted to the 2015 Hackaday Prize
This project is submitted for
  • Best Product
This project was created on 06/11/2015 and last updated 11 years ago.
Description
Deciding between the RGB Cube projects by Nick Schulze and Kevin Darrah lead me to the ultimate decision to build one cube that could work with either processor and either code. I then took it further and added I/O pins to allow multiple cube linking and spectrum analysis response with an MSGEQ7 module.
Build Instructions
Collapse
  • 1
    Step 1
    full instructions and descriptions and blog at http://www.instructables.com/id/8X8X8-RGB-LED-Cube
View all instructions
Log In/Sign up to comment
Sign up with Github
OR
Breakout/Bling Testing Board for IS31FL3736
Project Owner Contributor
MOUTHBREATHER
bradley-gawthropBradley Gawthrop
A very basic 555 IC LED Flasher board
Simple 555 LED Flasher
steve-smithSteve Smith
A pretty simple two board electronic Christmas Tree
3-D Christmas Tree
arduino-aficionadoArduino Aficionado
Quick Proto Board for 1204 Side View LEDs
Side View LED Prototyping Board
twinkletwinkieTwinkleTwinkie
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Universal RGB 8X8X8 LED Cube base and driver board", please tell us the reason.
Send message
Remove Member
