From idea to a working thing
A project log for Expandable breadboard
Solution for put wide boards/ICs into a breadboard, keeping the four connection holes for each pin
sufSUF 06/11/2015 at 03:240 Comments
This story is really short. Yesterday morning when I was driving to work, just pop into my mind, how can I solve my long lasting problem with the breadboards.
Some people had crazy solutions:
I was thinking about an easier way:
During the day I designed this thing, just in my head. Not drawing or writing a bit. In the afternoon I just run into the store and grabbed the things I didn't had at home. The sliders, the aluminum profile and the wood (I've pinewood at home, but I didn't wanted to run into a lengthy woodworking experience).
In the evening when everybody went to sleep, I started to work on it.
Picked one of the three breadboards, and cut it into two pieces with my proxxon micro table saw.
Cut the necessary FR4 boards, the aluminum profiles and the wood also. Drilled the holes into the necessary places, and screwed everything together. When it was done, glued the breadboards into its place with the original two sided tape attached into its back.
Finished. It took around two hours.
Probably fastest project of my life. :-)
Rich text editor
