Things are starting to come together. The board is routed, and I decided to use a 3-gang electrical box as the body, instead of trying to laser cut something. The only things left to figure out now is down to just a couple nuts and bolts...!
A project log for PhotonHome - AC Power IoT Homebase
The PhotonHome is the next step in bringing the Photon environment to AC powered applications
