https://www.kickstarter.com/projects/1260359869/swissmak-the-mill-turn-center-for-your-machine-sho
Main Turning Headstock
-Fits 4 (100mm), 5 (125mm), and 6 (150mm) inch chucks and collet noses.
-2 inch through bore, 50mm
-0 to 2000 RPM, limited by chuck rating
-Worm gear driven C axis, can be [dis]engaged in under a second. Will be pneumatic in production.
-Slides on heavy boxways
Milling Spindle Head
-Swivels on a rigid B axis to cut from any angle
-0 to 6000 RPM
-Can index to any angle and hold position
-Can rigid tap
-Works with 30 taper tool holders, no pull stud needed
Overall
-Approximately 5 feet long (1.5 meters)
-Weighs as much as a few adult humans
-Heavy aluminum construction (will be anodized in production version)
Realy nice job!!! As a cnc machinist from more than 10 years is a realy nice machine...simple, great design .
Im curious about the software you using to control it.. im familiar with mach3 and emc2 but i seach on your link but i didnt find where you talk about this
Well done
