Save the TARDIS by using the Doctor and your timestables
The build is complete. As you can now see in the gallery, we've finished making the box. It's very Blue Peter - a cardboard box and lots of sticky-backed plastic, but all the better for that. Here's Jack demoing it.
Large LEDs have arrived, and the final assembly has started. I made a video before I started this morning.
I managed to scrape together a few minutes last night. The 10mm blue LED for the roof has arrived yet, so I'm hoping it will come at some point today.
I've built everything out on the little breadboards now, including the roof LED (using a temporary substitute) and the speaker, and its all working.
I've only got one WT588D-u to use, so that is still on the original breadboard.
Tomorrow I'll shoot photos of all the components and the assembly process as I fit it in the cardboard box. Real soon now.
I've rebuilt the RFID and LCD components onto smaller breadboards that can be fitted directly into the cardboard box. I like this a lot as the breadboards are self adhesive, and you don't need to solder a custom board.
I'm waiting for my 10mm blue LED for the roof light, and I'm still exploring how to mount the speaker inside the case, and whether I should you a piezo.
Breadboard an Arduino Pro Mini onto a medium sized breadboard, along with a breadboard power supply. Wire the Arduino to power supply.
Wire the SPI pins of the Arduino onto two other small breadboards. Add an extra wire onto one of the breadboards to select the RFID reader, and two wires to the other board, one for selecting the LCD and one for the SD Card reader. Add +5v and Ground wires to each of the small breadboards.
Wire the RFID reader according the labels on your reader to one of the small breadboards. The reset line can be brought to Ground if you don't want to wire it in.
Very interesting idea just as so many others are using this strategy these days I would like to share some information about the Today telenor quiz and I think its good for you to carry one this project in future.
