I have started using pull-middle resistors here and there where appropriate and realized I hadn't ever tried these in combination with two-input diode gates. I already make common use of forward biased diodes with a pull-down to make a Max Gate and reversed biased diodes with a pull-up to make a Min Gate. Using forward biased diodes with a pull-middle gives this truth table:
Forward Biased, Pull 0 |
B |
0 |
A |
0 |
0 |
0 |
0 |
0 |
Using reverse biased diodes with a pull-middle gives this truth table:
Reverse Biased, Pull 0 | ||||
B | ||||
- | 0 | + | ||
A | - | - | - | - |
0 | - | 0 | 0 | |
+ | - | 0 | 0 |
Neither is of particular importance, but it's nice to keep that in my bag of tricks. The more gates I can make with fewer components the better. Sorry for the messy tables but not a lot of formatting options are available.
