The interesting thing about the first four two-input gates I devised (Min, Max, Antimin, and Antimax), was that they were just combinations of monadic gates 5 and P. Specifically, two 5's (Antimin), two P's (Max), two 5's passed through a 5(Min), and two P's passed through a 5(Antimax). This is important later.
Because I already had this set up on the breadboard I tried mixing the first set of 5's and P's to see what truth tables I would get out of them. I found four more interesting gates and eventually learned that the 5-P gate is called Implication, P-5 is called Converse Implication, 5-P followed by an inverter (another 5) is called Nonimplication, and a P-5 followed by a 5 is called a Converse Nonimplication. Here are the truth tables.
Implication
- | 0 | + | ||
B | B | B | ||
- | A | + | + | + |
0 | A | 0 | 0 | + |
+ | A | - | 0 | + |
- | 0 | + | ||
B | B | B | ||
- | A | + | 0 | - |
0 | A | + | 0 | 0 |
+ | A | + | + | + |
Nonimplication
- | 0 | + | ||
B | B | B | ||
- | A | - | - | - |
0 | A | 0 | 0 | - |
+ | A | + | 0 | - |
- | 0 | + | ||
B | B | B | ||
- | A | - | 0 | + |
0 | A | - | 0 | 0 |
+ | A | - | - | - |
And the schematic is here.
As a byproduct of trying to figure out what these gates should be called, I learned some pretty fundamental things about what I am trying to do with ternary logic that I was unaware of. I took a deep dive into symbolic logic to figure it out, but that's another post for another time.
