I've finished working out the ternary gate most closely analogous to the Binary XNOR gate. In Kleene logic it would be called the Biconditional or the Equivalence connective. I don't have a better name for it, so I'll borrow the boolean term XNOR. This was built using the expedient of copying the boolean method of chaining together four NOR gates like so:
In my ternary system I simply replaced the NOR gates with Antimax gates and it worked nicely. I think I may be able to simplify it a bit, but I'm not sure yet. Here's a picture of the resulting rats nest.
I tried out the "5E" boards as a replacement for a traditional breadboard. My analysis: They beat the hell out of breadboards in every single way. However, the manufacturing of the power rails is awful. Every insertion is a battle of will. If they just fixed that the 5E board would be totally superior.
In this circuit I changed things up a bit and used LM393's instead of the 319's I've been using thus far. That went pretty well.
And to continue the saga of my diode testing, I attempted this circuit using the small signal silicon diodes. Fail. After replacing a few at random with Schottky diodes it worked. Schottky all the way!
Enough jibber-jabber. Here's the schematic.
