Michael commented today on this project. He suggested I take a look at a Russian website.
The website (link) mentioned something about using a USB for flashing files, so I did a bit of googling.
I found this guide.
It's written that we first need to change the bootloader then flash the new image.
Everything is nicely written so I won't go into detail.
The MDT structure on the webpage does not match the on on my device. At least the bootloader structure looks ok. I'll do it anyway because I don't feel like waiting for soldering the UART pins.
I picked the USB way because it seemed simpler.
My USB was not at the SDA1 location, but at SDA.
# mount /dev/sda1 /mnt mount: mounting /dev/sda1 on /mnt failed: No such device or address # mount /dev/sda /mnt # cd /mnt # ls uboot128.img firmware.img
I later on successfully changed the bootloader.
# mtd_write write /mnt/uboot128.img Bootloader Unlocking Bootloader ... Writing from /mnt/uboot128.img to Bootloader ... [w]
But when I tried to flash the firmware ...
# mtd_write write /mnt/firmware.img Kernel_RootFS Could not open mtd device: Kernel_RootFS Can't open device for writing!
Because of course I don't have the Kernel_RootFS partition as I saw before.
So I looked at the comments and someone had the same problem.
It seems I need to use the the 32MB RAM bootloader, but first I checked how much memory I actually have.
# cat /proc/meminfo MemTotal: 28616 kB28616 / 1024 = 27.95 MB hmm wierd. Or I may have just converted this the wrong way. Anyway it's closer to 32 than to 16 so fuck it.
At this point, I can't remount the USB drive. And because I don't want to fuck up the bootloader I'll just try the other method.
*5 minutes later*
Ok so now the USB isn't at /dev/sda1 but at sdb
No need to try the other method. :D
# mount /dev/sdb /mnt # ls /mnt uboot256.img firmware.img
Success writing bootloader.
# mtd_write write /mnt/uboot256.img Bootloader Unlocking Bootloader ... Writing from /mnt/uboot256.img to Bootloader ... [w]
Success writing kernel.
# mtd_write write /mnt/firmware.img Kernel Unlocking Kernel ... Writing from /mnt/firmware.img to Kernel ... [w]
Fuck yeah.
So that's it for today I guess.
I'll write back to sellers on alibaba tomorow.
I already spent 2 hours on this today and I still have school work do do. :s
Thanks again to Michael and to the 3D Makers My embedded blog.
Domen
