Power Pin found!
A project log for CAN BUS Gaming Simulator
Controlling a VW CAN BUS dashboard of a Polo 6R with an Arduino and a CAN BUS shield using the Telemetry API of Euro Truck Simulator 2
leon-batailleLeon Bataille 06/14/2015 at 09:320 Comments
I've figured out the power pins of the dashboard:
These are the pin assignments of the 32 Pin Connector on the backside of the dashboard:
See: http://www.polo6rfreunde.de/index.php/Thread/9562-Pinbelegung-Tacho-Stecker/ (German
Pin 1 - encoders for fuel gauge 1 (fully)
Pin 2 - encoder for fuel gauge 1 (empty)
Pin 3 - encoder for fuel gauge 2 (full)
Pin 4 - Encoder for fuel gauge 2 (empty)
Pin 5 - Not used
Pin 6 - Not used
Pin 7 - immobilizer -D2- (1) (no engine control unit therefore present not available)
Pin 8 - immobilizer -D2- (2) (no engine control unit therefore present not available)
Pin 9 - speed signal output
Pin 10 - Unassigned
Pin 11 - Oil level and oil temperature sender -G266-
Pin 12 - Unassigned
Pin 13 - indicator light Rear fog light (probably digital 1/0)
Pin 14 - beam indicator light (probably digital 1/0)
Pin 15 - transducer for brake pad wear, front left -G34- / donors for brake lining wear, rear right (probably digital 1/0)
Pin 16 - Terminal 31 (GND)
Pin 17 - Sprinkler water level sensor -G33- (probably digital 1/0)
Pin 18 - transducer for coolant shortage indicator -G32- (probably digital 1/0)
Pin 19 - temperature sensor for outside temperature -G17- (in most cars is a PT100, ie analog input)
Pin 20 - Terminal 31, sensor ground (GND)
Pin 21 - call button for multifunction display -E86- (MFA +) (no engine control unit available so possibly alternative occupancy)
Pin 22 - call button for multifunction display -E86- (MFA) (no engine control unit available so possibly alternative occupancy)
Pin 23 - Memory switches for multi-function display -E109- (MFA-R) (no engine control unit available so possibly alternative occupancy)
Pin 24 - Unassigned
Pin 25 - Handbrake control -F9- (probably digital 1/0)
Pin 26 - Warning Contact brake fluid level -F34- (probably digital 1/0)
Pin 27 - Oil pressure switch -F1- (probably digital 1/0)
Pin 28 - CAN data bus combo, High
Pin 29 - CAN data bus combo, Low
Pin 30 - Unassigned
Pin 31 - Power supply Terminal 15 (12V).
Pin 32 - Power supply terminal 30 (12V).
The dashboard is connected to:
+12 V at Pin 31, 32 and GND at Pin 16, 20
Info: It needs to be connected to both +12V Pins. However it only needs +12V to run.
Rich text editor
