I found out the (or a) register that controls the kph gauge. But it reacts really strange.
The CAN register is 0x5A0.
Here is a script that provides settings for the RPM and KPH gauge as well as turning lights and backlight of the device itself. There are also many other CAN Codes. See also this list.
#include <mcp_can.h>
#include <SPI.h>
int fernlicht = 13;
int nebellicht = 12;
int bremse = 11;
int tempo = 0;
int rpm;
boolean hgb;
int blinker;
int tempBlinker;
// the cs pin of the version after v1.1 is default to D9
// v0.9b and v1.0 is default D10
const int SPI_CS_PIN = 9;
MCP_CAN CAN(SPI_CS_PIN); // Set CS pin
void setup()
pinMode(fernlicht, OUTPUT);
pinMode(nebellicht, OUTPUT);
pinMode(bremse, OUTPUT);
//Initialisierung
digitalWrite(fernlicht, HIGH);
digitalWrite(nebellicht, HIGH);
digitalWrite(bremse, LOW);
delay(1000); // wait for a second
digitalWrite(fernlicht, LOW);
delay(330);
digitalWrite(nebellicht, LOW);
Serial.begin(115200);
START_INIT:
if(CAN_OK == CAN.begin(CAN_500KBPS)) // init can bus : baudrate = 500k
Serial.println("CAN BUS Shield init ok!");
else
Serial.println("CAN BUS Shield init fail");
Serial.println("Init CAN BUS Shield again");
delay(100);
goto START_INIT;
void loop()
tempo = 10;
rpm = 1000;
hgb = false;
blinker = 3;
//Umrechnung KMH
tempo = tempo * 0.625 - (tempo*0.05);
//Umrechnung RPM
rpm = rpm * 0.0155;
// send data: id = 0x00, standrad flame, data len = 8, stmp: data buf
//ABS
unsigned char stmp1[] = {0,128};
CAN.sendMsgBuf(0x1A0, 0, 8, stmp1);
//RPM
unsigned char stmp4[4] = {1,0,0,rpm};
CAN.sendMsgBuf(0x280, 0, 8, stmp4);
//Lenkradschloss
unsigned char stmp6[2] = {0,128};
CAN.sendMsgBuf(0x3D0, 0, 8, stmp6);
//ESP & KMH enabled
unsigned char stmp7[5] = {0,0,0,0,0};
CAN.sendMsgBuf(0xDA0, 0, 8, stmp7);
//turning lights and backlight
unsigned char stmp5[3] = {blinker,0,hgb}; //1,0 = links; 2,0 = rechts; 3,0 = Warn
CAN.sendMsgBuf(0x470, 0, 8, stmp5);
//repeat kph signal
for(int i=0;i<5;i++){
unsigned char stmp[] = {1,128,tempo};
CAN.sendMsgBuf(0x5A0, 0, 8, stmp);
delay(30);
//Serial.println(i);
//Read CAN-Bus
unsigned char len = 0;
unsigned char buf[8];
if(CAN_MSGAVAIL == CAN.checkReceive()) // check if data coming
CAN.readMsgBuf(&len, buf); // read data, len: data length, buf: data buf
for(int i = 0; i<len; i++) // print the data
Serial.print(buf[i]);Serial.print("\t");
Serial.println();
delay(30); // send data per 100ms
The last big excluded code is to check what CAN commands go across the serial connection.Here's a little video demonstration for this code snippet:
Thank you for your big interest in this project!
Keep following. More updates coming soon.
