Temperature Pin Coding
A project log for CAN BUS Gaming Simulator
Controlling a VW CAN BUS dashboard of a Polo 6R with an Arduino and a CAN BUS shield using the Telemetry API of Euro Truck Simulator 2
leon-batailleLeon Bataille 07/16/2015 at 13:210 Comments
The temperature sensor of the Volkswagen Polo V (6R) seems to be a NTC temperature Resisitor (3.3kOhm).
We played a little bit with it :D
Uh, frosty...
We figured it out using a potentiometer resistor, playing a little bit with. We ordered a NTC resistor (3.3kOhm) which should work as a easy room temperature sensor.
Here's a table with some values we found out:
Rich text editor
