A while ago I mentioned that I want to add a touchscreen to the project in combination with the RNS software I programmed.
As I also wanted to put all circuit boards into a box together with the display, this is the first big step for building this box or case.
You've already seen the plan of the display frame, but this is a photo of the printed version. Remember: I still have to polish it a little bit...
Leon Bataille
