I'm in the process of building an Installation and Setup Tool for those of you, who wanted a detailed instruction on how to set everything up. This software does the job for you!
I hope to complete this Setup Tool as fast as I can.
Here's already a screenshot (You can manually choose the packages which you want to install)
Leon Bataille
