Hackaday.io Hackaday.io
Sign up Log in
Smart watch Journal
Modify/make a smartwatch with a user facing camera to record those all important logs when you're lost in space
j0z0r-pwn4tr0nj0z0r pwn4tr0n
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
5 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
  • The 2017 Hackaday Prize
View Gallery
837
0
5
5
Team (1)
  • j0z0r-pwn4tr0nj0z0r pwn4tr0n
Join this project's team
ongoing project
smartwatch MSP430 Journal 2017HackadayPrize
This project is submitted for
  • Design your concept
This project was created on 06/14/2015 and last updated 10 years ago.
Description
A smartwatch with the capability to record videos and play them back. How else are you gonna be a sci-fi kid making your video journal or stranded miner on the Deimos refinery? This could be done with current smartwatch technology (even the cheap Chinese ones), except maybe for the lower quality screens. One hurdle would be a good battery life and still be thin enough for practical use
Project Logs
Collapse
  • Maybe sourced the board...
    j0z0r pwn4tr0n • 04/22/2017 at 03:06 • 0 comments
    I backed the indiegogo for the Lichee Pi Zero, and hopefully it will be arriving in the next month or so. If you haven't heard about it, it's basically an SD card sized, breadboardable Pi Zero clone. Here's some links:
    https://www.indiegogo.com/projects/licheepi-zero-6-extensible-linux-module-on-finger-wifi-diy#/
    https://liliputing.com/2017/03/lichee-pi-zero-tiny-linux-computer-module-6-crowdfunding.html
    https://hackaday.io/project/20181-lichee-pi-zero
    The form factor is perfect, and it already has support for the types of small cameras I would need to be running.
    I'll start fleshing out this project more as I do the research and design
View project log
Log In/Sign up to comment
Sign up with Github
OR
As seen in Evangelion series. Asuka's handheld console based on Wonderswan.
Project Owner Contributor
Apple Bandai PIPPIN 256GB from Evangelion
productionproduction
A video and still camera based on the Raspberry Pi A+. The camera has integrated bluetooth and wifi for file transfers, as well as an on-boa
Raspberry Pi Action Cam
connor-yamadaConnor Yamada
Official Hackaday Prize Entry
DIY Google glass but done properly
£100 Google Glass using Raspberry Pi
danielmcgrawdanielmcgraw
Low cost autonomous underwater camera for long term deployments and exploration
PipeCam: Low-Cost Autonomous Underwater Camera
fred-fourieFred Fourie
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Smart watch Journal", please tell us the reason.
Send message
Remove Member
