I just wanted to show two tools I use to people who are reading my logs (if any), both are free for non-commercial projects.
I use Toggl for tracking time, it's awesome, integrated into Gmail, Trello (more on that later) and a lot of other tools, multi platform, allows you to add an entry manually and can show you how much time you've spent on your projects.
This is the web view (I write some things in Slovenian).
There is also a nice report feature so you can see time spent on projects:
I also use Trello for managing projects and for writing todo lists, writing ideas ...
In the next log I will write about my experiment with hydroponics.
I would like to end this post with an inspiring quote:
“You are confined only by the walls you build yourself.”
Andrew Murphy
