| Reference | Value | Footprint | Cost / Board | Supplier | Quantity Required | Notes |
| IC1 | ATTINY4313 | Housings_SOIC:SOIC-20_7.5x12.8mm_Pitch1.27mm | 1.59 | Newark | 1 | |
| C1 | 0.1uF | Capacitors_SMD:C_0603 | 0.00359 | Digikey | 4000 | X7R |
| C2 | 0.1uF | Capacitors_SMD:C_0603 | 0.00359 | Digikey | 4000 | X7R |
| C3 | 0.1uF | Capacitors_SMD:C_0603 | 0.00359 | Digikey | 4000 | X7R |
| C4 | 0.1uF | Capacitors_SMD:C_0603 | 0.00359 | Digikey | 4000 | X7R |
| C5 | 0.1uF | Capacitors_SMD:C_0603 | 0.00359 | Digikey | 4000 | X7R |
| C6 | 0.1uF | Capacitors_SMD:C_0603 | 0.00359 | Digikey | 4000 | X7R |
| C7 | 0.1uF | Capacitors_SMD:C_0603 | 0.00359 | Digikey | 4000 | X7R |
| C8 | 0.1uF | Capacitors_SMD:C_0603 | 0.00359 | Digikey | 4000 | X7R |
| C9 | 0.1uF | Capacitors_SMD:C_0603 | 0.00359 | Digikey | 4000 | X7R |
| C10 | 0.1uF | Capacitors_SMD:C_0603 | 0.00359 | Digikey | 4000 | X7R |
| C11 | 0.1uF | Capacitors_SMD:C_0603 | 0.00359 | Digikey | 4000 | X7R |
| C12 | 1uF | Capacitors_SMD:C_0603 | 0.1 | Digikey | 1 | X7R |
| U3 | IS61LV5128AL | Footprints:tsop2-44 | 4.85 | Jameco | 1 | |
| U1 | LTC6903 | Housings_SSOP:MSOP-8_3x3mm_Pitch0.65mm | 3.92 | Digikey | 1 | |
| U2 | XC95144PQ100-100TQFP | Housings_QFP:TQFP-100_14x14mm_Pitch0.5mm | 7.25 | Digikey | 1 | |
| R2 | 4.7k | Resistors_SMD:R_0805 | 0.018 | Digikey | 10 | 5.00% |
| R1 | 10k | Resistors_SMD:R_0805 | 0.018 | Digikey | 10 | 5.00% |
| R3 | 10k | Resistors_SMD:R_0805 | 0.018 | Digikey | 10 | 5.00% |
| R4 | 10k | Resistors_SMD:R_0805 | 0.018 | Digikey | 10 | 5.00% |
| FID1 | CONN_01X01 | Fiducials:Fiducial_1mm_Dia_2.54mm_Outer_CopperTop | 0 | 5.00% | ||
| FID2 | CONN_01X01 | Fiducials:Fiducial_1mm_Dia_2.54mm_Outer_CopperTop | 0 | 5.00% | ||
| R11 | 510 | Resistors_SMD:R_0805 | 0.021 | Digikey | 10 | 1.00% |
| R12 | 1k | Resistors_SMD:R_0805 | 0.021 | Digikey | 10 | 1.00% |
| R13 | 2k | Resistors_SMD:R_0805 | 0.021 | Digikey | 10 | 1.00% |
| R8 | 510 | Resistors_SMD:R_0805 | 0.021 | Digikey | 10 | 1.00% |
| R9 | 1k | Resistors_SMD:R_0805 | 0.021 | Digikey | 10 | 1.00% |
| R10 | 2k | Resistors_SMD:R_0805 | 0.021 | Digikey | 10 | 1.00% |
| R5 | 510 | Resistors_SMD:R_0805 | 0.021 | Digikey | 10 | 1.00% |
| R6 | 1k | Resistors_SMD:R_0805 | 0.021 | Digikey | 10 | 1.00% |
| R7 | 2k | Resistors_SMD:R_0805 | 0.021 | Digikey | 10 | 1.00% |
| F1 | 0.75A HOLD 6V PTC | Resistors_SMD:R_1210 | 0.2544 | Newark | 10 | |
| U4 | NCP1117ST33T3G | Footprints:SOT223_PWR | 0.49 | Digikey | 1 | LDO Not Needed |
| C14 | 10uF | SMD_Packages:SMD-1206_Pol | 0.4848 | Newark | 5 | Tantalum, 6.3V |
| C15 | 10uF | SMD_Packages:SMD-1206_Pol | 0.4848 | Newark | 5 | Tantalum, 6.3V |
| C13 | 47uF | SMD_Packages:SMD-1206_Pol | 0.0672 | Newark | 1 | Tantalum, 6.3V |
| P6 | CONN_02X03 | Pin_Headers:Pin_Header_Straight_2x03 | 0.06 | |||
| J2 | VGA-HD-15 | Footprints:HD15_B-HD15F | 1.18 | Newark | 1 | Newark 54M6031 |
| C16 | 22pF | Capacitors_SMD:C_0603 | 0.024 | Digikey | 10 | X7R |
| C17 | 22pF | Capacitors_SMD:C_0603 | 0.024 | Digikey | 10 | X7R |
| Y1 | 7.3728 MHz | crystal:HC49_sm | 0.325 | eBay | 20 | MFG Not Important |
| P1 | CONN_01X03 | Pin_Headers:Pin_Header_Straight_1x03 | 0.03 | |||
| P2 | CONN_01X05 | Pin_Headers:Pin_Header_Straight_1x05 | 0.05 | |||
| P3 | CONN_01X02 | Pin_Headers:Pin_Header_Straight_1x02 | 0.02 | |||
| P4 | CONN_02X03 | Pin_Headers:Pin_Header_Straight_2x03 | 0.06 | |||
| P7 | CONN_01X30 | Footprints:DF40C-30DS-0.4V | Optional | |||
| D1 | Green LED | LEDs:LED-0603 | 0.0495 | Jameco | You Pick Color | |
| R14 | 330 Ohm | Resistors_SMD:R_0805 | 0.212 | Digikey | 5.00% | |
| R15 | 150 Ohm | Resistors_SMD:R_0805 | 0.212 | Digikey | 5.00% | |
| R16 | 150 Ohm | Resistors_SMD:R_0805 | 0.194 | Digikey | 5.00% | |
| D2 | Yellow LED | LEDs:LED-0603 | 0.0495 | Jameco | You Pick Color | |
| D3 | Orange LED | LEDs:LED-0603 | 0.0495 | Jameco | You Pick Color | |
| P5 | USB_B | Connect:USB_B | 0.5528 | Newark | Newark 14N8154 |
Total cost before PCB service: $22.88 (plus shipping), not including optional DF40C-30DS-0.4V ($.81 at Digikey)
PCB Service at Elecrow: $1.10 (plus shipping)
Total estimated cost: $23.98 plus shipping
PK
