In the following weeks I will try to improve the python/pyqt application that lets you take photos easily (showing the preview and letting you push a button to make a photo or video without being in fullscreen). If you are not running raspbian (I run ubuntu mate), you have to follow these steps to make the camera work.
1) Make the user a member of 'video' group:
sudo usermod -a -G video [your_username]
2) Add /opt/vc/bin
to your $PATH
PATH=$PATH:/opt/vc/bin
3) set up your /boot/config.txt
to contain the following:
gpu_mem=128 start_file=start_x.elf fixup_file=fixup_x.dat # optionally: disable_camera_led=1
4) Download the 3 files from and put them in the same folder:
5) Open camera.py with IDLE (using Python-2.7) and Run the module.
