@SUFs USB-B breakout
A project log for Breadboard Widgets
A collection of widgets/adapters/breakouts to make prototyping easier/faster
stefan-lochbrunnerStefan Lochbrunner • 07/16/2015 at 17:45•1 Comment
Here's another contribution from @SUF:
The original repo for this USB-B breakout can be found here. As with the audio breakouts, it has also been merged into this projects repo. And again, the schematic should be obvious from the board file:
I'm thinking about turning the uUSB breakout into a general USB breakout with multiple footprints. That would also mean that I'd have to remove the regulator from the board but then I'd make a separate board for different voltage regulator footprints. Thoughts?
SUF wrote 07/17/2015 at 04:55 • point
Hi Steve,
Thank you, for writing about these. I'm on vacation now anyway. Back in August. :-)
SUF
