This log will be a repository and notes for 3Dprinted parts that I have designed for use in the prototyping and even early small run production for the UFARM Robotics Project.
The grow light hanging clip was necessary to provide a bracket that could mount both light fixtures and utilize the carabiner for suspension. The specific fixture is 42 mm x 30 mm in the cross section for mounting. I am moving to LED's as the project progresses so I will not be remixing for other T-8 fixtures.
