Ran some tests to determine the values of the resistor and capacitor on the temporization network that generates the P/S signal from the CLOCK signal. Also changed the delay loops in the program in order to take less time to complete all the shifting.
The resulting values are:
- Resistor: 4K7
- Capacitor: 4n7
- Delay time from CLK low to P/S low: 100us (above 50us is OK)
- Total time spent shifting the 48bits plus start and final delays: 442us. It might be necessary to synchronize the reading of the bits with the USB interrupts.
- Bit Shift timing: 6,8us (174KHz)
