Almost there! I just have one small cosmetic detail left I think. I added the shutdown button to the back panel and mounted the big button in a box with long cable and connector. The back cord hole is felt backed for better appearance as well. A couple of concerns have come up:
- Sometimes the photo sequence false triggers from interference on the button line with the long lead. It's annoying at best, but if it also gets into the shutdown line it would make the unit unreliable.
- It gets warm inside. Not too much to be worried, but something to keep an eye on I suppose.
