Another successful static test. With this log post I will create a standard naming scheme for static motor tests. Logs will start with ST and ends with an auto increment numerical value. After will follow case diameter, bore size, nozzle choke width, and propellant batch size.
Sorry for the video orientation, I was trying to capture as much exhaust as possible
J. M. Hopkins
