Piston Ejection Tests
A project log for High Power Experimental Rocket Platform
Experimental high power rocket with active stabilization, live telemetry, autonomous GPS guided recovery and HD video
j-m-hopkinsJ. M. Hopkins 09/18/2015 at 03:300 Comments
Began testing the piston system for parachute deployment. I used a spare body tube to limit the chance of catastrophic failure during testing that would result in damage to my lower body assembly. I'm using Pyrodex for the charge itself.
