Did a first attempt at assembly today. Generally working but will need to source some shorter cables, it's a bit crowded inside the enclosure. Also not 100% sure about the gooseneck assembly. It's very good, but also a tad heavy, and for a helmet mounted device it may be too much. Nice clean install tho, the display cable routes inside the gooseneck. Will take some pics once I find shorter cables, right now it's spaghetti city in there and looks pretty garbage.
