HiDPI support added
A project log for BowlerStudio: A robotics development platform
Make cooler robots, faster and with less effort.
kevin-harringtonKevin Harrington 04/22/2024 at 18:220 Comments
I have finally managed to add support for HiDPI monitors. User just needs to use the menu to select a font size, and all the text in the application and all the Icons will resize to match the new size. The main window will also detect the font size setting to set the initial size of the window. Font size is stored in the applications configuration so it is persistent from opening to opening and across work stations.
Rich text editor
