Though the old Tesla keybaord I described here and here and described by @Benchoff in #Metal Dome Keyboard is still in my drawer in amount higher than small, I'm looking for alternatives for my MiniBSD.
I found one in here, for the case the listing is unavailable, here is screenshot
I dissected the thing on arrival and didn't bother whether it works or not
Not the cleanest example of engineering work, but for quick testing it is adequate. There is PIC16F1519 on board, testing all combinations of wires for conductivity few times per second and pushing results via serial port. Not exactly interesting thing, but quick and ugly test sources will be available for download in the "files" section.
where line 11 is unused, being apparent on pictures above - or translated into keyboard layout
For example, pressing key Q connects lines 20 and 7.
jaromir.sukuba
WOW !
I have the same kbd/holder, bought as a set with a screen...
It's a great news that there are solderable pads on the controller !
Unfortunately it's QWERTY and not AZERTY...
Some of the PC keyboard USB controllers also support PS/2 interface. It is quite easy to bitbang the PS/2 protocol on a micrcontroller.
https://hackaday.io/project/1347-fpga-computereval-board/log/9320-ps2-interrupts-driver
