Now it's on right direction
A project log for SD card sized board, let's say "SDuino"!
Once I was excited to see Intel's announce that they will release "SD card sized computer" but it was not true. This time I made it true!
microwavemontmicrowavemont • 09/14/2015 at 13:16•3 Comments
The previous "SDuino on wrist" was a bit hard to read its digit and Nyancat, so this time,,
I rotate 90 deg to read well !
The function and circuit is exactly the same (Lipo battery and charging circuit), but
I inserted a string of plastic sheet (actually it is SD card holder cut by scissors...)
and it is working as "very low-efficiency light-wave waveguide". When it turns green, battery inside is full, and will turn red during charging....
Aexander Beta wrote 09/15/2015 at 04:45 • point
That's amazing! What all does it do currently?
davedarko wrote 09/14/2015 at 13:47 • point
that looks awesome :)
microwavemont wrote 09/14/2015 at 13:55 • point
Thank you!!!!
