Development Day 45
-uhr value is reset to 0 and saved when uhr is hidden because less than 10 plugs are used
-moved plugs down one pixel on DrawSteckerTop
-rewrote DrawRotorBoxContents, no flicker and pins display right, draws ok when flat rotor visible & returning from plugs
-need to eliminate display bugs on DrawMechanismRotors
-Draw Mechanism rotors now switches from short to long rotors-need to align pins and erase greek rotor type when switching
DrawMechanismRotots works, switches from short to long, erases old gamma rotor, draws pins on long & short
