Calibrating the DACs ( Programmable voltage sources)
A project log for A Versatile Labtool
A cost effective, multi-pronged data acquisition tool to turn your computer into a workbench for science and electronics experiments.
jithinJithin • 08/13/2015 at 08:22•0 Comments
DACs have non-linearities that are repeatable, but are not usually periodic. Hence, generating a single calibration polynomial is difficult (At least up to a few orders ). A lookup table is the general solution for making an accurate programmable voltage source. Read more about INL errors here
The following image shows the deviation of one of the programmable voltage sources (resolution 1.6mV. +/-3.3V range) from the expected value(red trace) , and the accuracy of the same post-calibration(yellow trace ). The PIC has copious amounts of flash, and lookup tables and calibration constants can stored in it and loaded by Python upon initialization.
The overall slope and offset is caused by the amplifying op-amp and corresponding resistors, and can be fixed with a second order polynomial easily.
The jagged shape however, is a property of the DAC itself, and is corrected using a lookup table that stores the error in each code in terms of number of codes to skip forward/backward in order to achieve the highest resolution without compromising on accuracy.
*As of this writing, the DAC calibration data is being loaded from text files for testing. They have not been written onto flash memory for the three units I've shipped to SupplyFrame for the Best Product Prize.
