Documentation, and interactive help
A project log for A Versatile Labtool
A cost effective, multi-pronged data acquisition tool to turn your computer into a workbench for science and electronics experiments.
jithinJithin • 08/20/2015 at 17:32•0 Comments
Documentation for the python module is generated with sphinx, and is bundled with the source. It's also hosted online at pythonhosted.org/vLabtool/
In addition to this, the experiment framework has been modified to display a custom webpage for each experiment.
There is also an imagemap of the vLabtool that shows tooltips on mouseover on various regions
The interactive tooltips are made with CSS and HTML, and I learnt this from http://www.websitecodetutorials.com . The webpage is embedded using QtWebKit.
Here's a shortened example of my code for that map if you want to implement something similar.
<!DOCTYPE HTML><html><head><meta charset="UTF-8"><title>Image Map for the vLabtool</title>
<style type="text/css">
body{text-align:center;}
h2{position:absolute;top:0;left:0;font-size:25px;margin:10px 0 0 10px;}
#map {
position:relative; height:620px; width:800px; margin:0px auto; background:url('_images/SWrender.png');}
a:hover {
visibility:visible; /* Fixes IE6 Bug */
.wavegen_amp { position:absolute;
left:96px;top:385px;width:100px;height:60px;
text-decoration:none;color:#000;
.wavegen { position:absolute;
left:270px;top:300px;width:40px;height:40px;
.wavegen_amp span ,.wavegen span{
position:absolute;
left:-999em;
opacity:.8; /* FX/Opera/Safari/Chrome */
-ms-filter:"alpha(opacity=80)"; /* IE8 */
filter:alpha(opacity=80); /* IE6/IE7 */
border-radius:8px;
box-shadow:#201 2px 2px 6px;
.wavegen_amp:focus span,.wavegen_amp:hover span ,wavegen:focus span, .wavegen:hover span{
left:00px;
top:30px;
width:150px;
padding:10px;
border:2px solid #201;
background:#aaa;
</style>
</head><body>
<span>Mouse over for details</span>
<div id="map">
<a href="#" class="wavegen_amp"><span>Amplitude control for the waveform generator</span></a>
<a href="#" class="wavegen"><span>Programmable waveform generator output. eg. set_sine(3000.25)</span></a>
</div>
</body></html>
