I will examine several different methods to fabricate PCBs from Dupont Pyralux - a flexible PCB material consisting of a copper layer glued to a Polymide film backing. These experiments are performed on 1oz single-sided Pyralux purchased from Ada Fruit. For reference, the copper layer is 35um thick and the Polymide backing 25um. We start by attempting to make a circuit board using a LPKF ProtoMat C60 circuit board cutter.
ProtoMat C60
I created a baseline by making different depth cuts in 1oz copper on a standard FR4 substrate. The depth limiter on the C60 is adjustable in 4um increments by turning a knurled nut. I made 10 passes, starting a 0um depth and going 20um deeper on each pass. The FR4 substrate has a less shiny appearance than the copper.
From the microscope pictures (excuse the rough quality), it appears that 40um is sufficient to cut through the copper. This is pretty close to the 35um thickness of 1oz copper. In order to insure clean edges, we typically cut our PCBs to a depth of 100 - 150um depending on the quality of the cutting tool.
First Attempt:
With the help of hindsight, my first attempt had three problems. The spray adhesive was old and lumpy when applied to the back of the Pyralux. Second, I pressed Pyralux foil down with my fingers to attach it to the backing material. Third, the press board backing was not very rigid. The engraving was not consistent as shown in the figure below.
Second Attempt:
After some reflection and a visit to my local big box store, I returned with a new agenda - to attach the Pyralux as flat as possible. I accomplished this by mounting the Pyralux onto a sheet of FR4 (labeled 1 in the Figure below). I lightly sprayed one coat of the Loctite spray adhesive onto to the back of the Pyralux sample (labeled 3 in the Figure below). I then placed the glued sample onto the FR4 (labeled 4 below) and pressed the ever living hell out of it using a piece of scrap PCB material (labeled 2).
I proceeded to make 10 different depth cuts starting at 0um depth and going 20um deeper on each pass. This setup resulted in much more consistent results then my first trials. The image below is taken through the eye-piece of our microscope. The 40 and 60um deep cuts have a dull brown streak down the center; the same color as the Polymide backing. The Polymide was cut completely through on all cuts beyond 60um. The dark brown streak in the cuts deeper then 120um is the fiberglass core of the FR4 used as the underlayment to the Polymide.
The following figure shows the Pyralux partially peeled away from the raw FR4 sheet. This clearly illustrates that cuts deeper than 60um will penetrate all the way through the Pyralux. this should not come as a surprise as the Pyralux is a total of 60um thick.
To test if this methods was practical, I cut the following "circuit board". This pattern stressed the Pyralux in all directions as the C60 cutting head worked its way around the spiral.
I will come back later and make a post about that I am going to do with this board. But first, I have a couple of novel ideas on how to chemically etch the Pyralux. So stay tuned - I'll be posting early next week.
July 17th update:
I have been working two fronts on this project. First building the etching tank. This is turning out to be a pain in the ass finding leaks all over the place. The second, looking at methods to transfer the negative of the circuit to a regular PCB. I'll focus on the second here - I need to record some data
After looking at this Ben Heck episode, I decided to try his laser cutter method of removing the etching mask from a PCB.
In theory, the idea is pretty straight forward. Spray paint a PCB with a uniform coat of paint. Next drop the PCB into your laser cutter and burn away the paint anywhere you want to remove copper. The paint protects the copper from the etchant while the exposed copper is removed. This idea is illustrated below.
In order to cut the track, you need to provide the laser cutter with a path. this is pretty straight forward - have your favorite PCB layout tool export a vector graphic of the top layer. In my case, I have EAGLE export a encapsulated postscript. Then import it into your favorite laser cutter editing software (Corel Draw). If you haven't already realized it by now, you will see that the PCB tracks exported by EAGLE are a thin path. You need the negative of this path if you are to preserve the PCB track after etching. Fortunately for me, Corel Draw has a Cut Outside function. This function produces two paths (Laser track in the figure below) surrounding the PCB track (Line width in the figure below) exported from EAGLE. You need to make some adjustment to the Line Width because the laser beam has a non-zero width and will consequently eat into the PCB track you are trying to protect. Consequently, you first need to increase the width of the PCB track in Corel Draw. This calls for some experimenting.
My baseline was a 16 mil PCB trace; imported into Corel Draw as a 1.152 point width line. I made a series of lines with increasing width from 16 to 32 mils. I then cut around these traces and measured the remaining paint width with calipers. Subtracting the paint width from the line width width yields the beam width.
Line width (points) | Line width (mils) | Paint width (mils) | Beam width (mils) |
1.152 | 16 | 7 | 9 |
1.44 | 20 | 10 | 10 |
1.728 | 24 | 14 | 10 |
2.016 | 28 | 18 | 10 |
2.304 | 32 | 22 | 10 |
Yup, my laser cutter burns a 10mil track. I probably could have derived this using a simpler process, but hey I really wanted to see the needed line widths.
Well thats all for now. Hopefully, I'll get the etching tank leaks plugged early next week and start etching.
