My in-law's farm recently suffered serious damage when the nearby river burst it's banks and flooded their paddocks and sheds. The area is distant from their house.
This project aims to provide a cheap and reliable sensor at the riverbank to detect a dangerous rise in the water level and provide an audible/visual alert in the house - with enough warning so they can move livestock and equipment in time.
Have been busy mulling over the various hardware elements and preparing to order parts.
After looking at a few related projects here (well-watcher) I've decided to try an ultrasonic rangefinder-type device to detect a rising water level.
I wanted to avoid any moving parts, which ruled out my original float-based idea.
I was thinking about using a pressure sensor, where the rising water in a 'vessel' would cause the air pressure to rise, but I was unsure how I would calibrate this..
Also switched to the APC220 radio module for better range.
Definitely interested to see what you come up with for a sensor. Lots of potential technologies out there that could work, all of which have tradeoffs. Great project!
