Some years ago, the Swedish physician Torsten Thunberg discovered a thermal illusion. If you take 2 different temperatures, both temperatures being in the comfortable range, but alternate them on the skin, then a very powerful sensation of burning is felt. This was called "Thermal grill illusion", and it reminds of the Bene Gesserit's Pain Box Test, from the amazing Frank Herbert's book, "Dune".
This is a device that reproduces the thermal grill illusion using 5 cheap Peltier elements:
- Align 5 pieces of TEC1 - 12706 thermoelectric Peltier elements at about 1 cm each.
- Connect all of them in parallel, and apply about 7.5 Volts.
- No fan or temperature control is necessary at room temperature. Natural convection is enough.
Does it really works? Absolutely!
It works surprisingly well.
3D Printing AVR Arduino Art Audio Automation BeagleBone Bluetooth Cameras Clock Drones Environment Hardware IoT LED Medical Music Radio Raspberry Pi Remote Control Robotics Rockets Satellites Science Security Software Virtual Reality Wearables
Feels intense pain- decides to test with tounge :)
